C
cy
with winter sitting in all over the US.... there's got to be dying car batteries all over.
much better to catch a battery on the way out and replace ahead of time....instead of getting stuck.
hence the question:
testing lead-acid batteries.... electronic tester vs traditional load tester.... which is better?
Electronic lead/acid testers have been available for quiet some time. depending upon features of tester ...will test for bad cells, number of cold cranking amps, surface charge condition, etc. will give digital readout of condition.... one drawback is temperate of cell can distort readings... if tester doesn't have a feature to compensate for temps. tester will give false readings.
vs a traditional load tester hooks up battery to a mondo sized resister. which of course mimics the 300+ amps a starter motor can place on a battery. load test is quite simple... if battery can sustain load.. it passes
then let's factor in AGM cells... charging systems... corrosion on battery clamps... etc.
so which is better?
Electronic tester vs load tester
for test mules, got a Cornwell KA-8300 electronic tester made by SPX, Schumacher Speedtest and an ancient battery load tester with big honking resister coils in parallel.
hence the question:
so which is better?
