Re: The best torch (I own) for nightime bush survival is...
Shhhhhh this is a secret !
Have you tried a golf Buggy/caddy/cart , the two wheel folding ones , buy a strong one and just pull it behind you .
I went looking at tents today , and all the nice ones weighed so much , then I thought - 2 wheel buggy .
That would be good with a path, or light off road stuff, even dirt roads and scrub it could handle.. but I dont think it would have helped with the.. almost cliff... I was going up
I used to carry that amount of weight walking 20km a day for 3 or 4 days in a row, I have just gotten slack recently. Need to get fitter again. Should only be 3 or 4 months work and I will be able to carry that bag without to much trouble (I mean I already can on the flat..).
As for tents, they are just trouble really, they are either cheap and leak, insanely expensive, or the good old canvas ones, that are too heavy to carry.
I now use "hootchies" exclusively. I take 2 hootchies, folding shovel, hammock, sleeping bag, paracord and self inflating mattress as my shelter/bedding. I improvise pegs out of sticks/rocks/trees i find onsite, saves carrying them.
I dont normally use the hammock, I generally just set up the hootchie, dig a trench around if I think it may rain, and use the second hootchie as a groundsheet if i feel like being clean, or set it up as an additional roof If i want that...
If its going to be freezing cold instead of having the "roof" hootchie up in the trees (like I normally do) you can peg it to the ground, get a stick of the right lenth at one end to keep it off the ground. Lay the second hootchie inside making sure you sort of fold the edges up (so the water goes underneath). Then you can get the shovel, dig a trench around and lightly cover the edge of the "tent" to keep the breeze out.
There is of course still one open end of the tent, so you need to try and aim this away from the wind, and/or build a wind-break out of sticks and dirt (remember you have a shovel now.. ).
If your short enough to crawl down the end and pull up the groundsheet to block the entrance you can do that, unfortunatly I am not lol.
In summary, Hootchies are better because they are simple, light, cheapish and adaptable. For the space of 1 tent you could carry 4 of them, imagine the options then
