smokelaw1
I'm here every day. Doesn't that count? :nana:
Cute. I can think of about 1,000 people who would be so kind as to "volunteer" some time to test the new LS. For the record, I am also one of them.
I think you missed a "0" in there, Tim. It's 10000 posts minimum for doing evals.Unfortunately for you, nobody with under 1,000 posts is eligible. Sorry bout yer luck.
:shakehead
:laughing:
This is not my first rodeo.
peter
:shakehead
:laughing:
I would be VERY interested in doing some field testing if you happen to need non-technical, EDC, everyday guy kinda feedback.
:naughty:
Tim
If you would like to post I am sure R&D funds would be accepted.:nana:
I'm not sure what you mean by traditional beam distribution or even that there is such a thing. Surefire, for example, is well known for making lights with wide beams based on the idea that small lights are mostly used at near and medium distances. They have some interchangeable turboheads for those who need throwers. I myself prefer wide beams. I got a P--k Pacific recently and its beam is much narrower than I'd like; quite small hotspot and rather dim spill that is itself narrower than some other lights. IMO the Arc4+ beam was slightly on the narrow side though still satisfying.The cree xlamp package already has been fitted in the LS as you know (see bare Al prototypes in pictures). However, the resulting beam doesn't throw as far as the P4 or K2. The center spot is less powerful while the flood is more powerful. The change is significant and in my opinion, less desireable. This could be fixed by making the head larger, but any dolt can make a light brighter by making it bigger. I would rather wait for the same high flux die to end up in a better package (p4). Modders can put in whatever LED they want (within reason), but our main offering will be more in line with the traditional beam distribution people expect from an EDC.
peter
A big and soft hotspot with a concentrated spill and gentle transition has huge benefits in near an dmedium field illumination and is, IMHO, preferable over a bright and small spot with a pale spill. Especially in lower illumination modes where this spill will be useless and the high contrast between spot and spill makes it way more difficult to use.
But then again .. this is IMHO
bernie
