Thrunite Low Voltage 1.5A XP-G dropin with 3xAAA
caall99
Question is as follows can i mate this:
ThruNite 1.5 Amp XP-G P60 Size 2.7-4.2V Drop-In, 3 Mode
http://flashlightconnection.com/Thru...Mode-p306.html
With this host:
Solarforce L2i Sand AAA/18650/CR123A Flashlight Body
http://internationaltradingcompany.n...t=FBs=9id=29
Using 3xAAA
Will this overdrive and hence burn out the LED?
3xAAA can range from 3.6v (1.2v ea) to 4.5v (1.5v ea) fully charged..or even more... if i can make this setup work then i have definitely found my dream light. Then again... maybe in the L2i the batteries are hooked up in parallel...
