the gray ones a slightly thicker and longer then the blue unprotected 16340I have a couple of UltraFire 16340's. With the digital caliper set at 16.70 mm you can turn around the cell. Minimum reading 16.50 mm.
just a note, i havnt yet found a use for the Gray ones, they just dont fit anywhere.
Awaiting the arrival of Spartanian II which will be able to accept them I use them in my Lumapower LM33 with excellent results. The extra length is not a problem there.
Raymond said:Dimensions of the cells (L*W in mm):
Batterystation: 34.4*16.7
DX11670 (white TF):35.9*16.7
DX8683 (grey TF):35.8*16.6
DX3273(ultrafire):35.8*16.8
KAI4512:34.5*16.5
AW:34.3*16.6
