aim54x
Following that logic, FHM, Maxim, and GQ should stop taking pictures of those hot chicks...:thumbsdow
Bring on the overdone pics of tritium in lights! *drools*
Greetings, i'd like to install a vial in my Nitecore D10 using Norland 61. But i'm not sure which UV light is the best to cure it and what's the best way to get a good result. Never used this stuff before. And there are only two UV lights available here - a usual mosquito lamp or a 300 watt mercury lamp from our chameleon, i was told it needs a few minutes to gain full power. But i'd like to ask a few questions before starting.I use a mosquito lamp.
Final cure means i can already use the piston after 10 minutes ? Or do you place it in sunlight for a few hours ?[SIZE=-1]The final cure can be accomplished in 5 to 10 minutes using the 100 watt mercury lamp.[/SIZE]
