typical newbie "suggest a flashlight" thread
evnash
well here goes anyway. i will be getting married soon and moving out into the woods from the city. I would like a pretty good flashlight for general use (walking a night in the country, lighting up the back yard, etc) so i guess i was something that is a mix of a good thrower and good flood. i dont mind buying non standard batteries and a charger but if i can get away with a standard Nimh batts i already have a charger. I want to spend around $50 total. i have a couple flashlights already that say they are 150-200 lms but who knows what they actually put out. i want something way brighter than that.
so suggestions...and where to get the best deal would be great too. thanks guys.
I am pretty new to this, but I would be looking at Fenix and Nitecore for good value for money whilst delivering solid quality. They may be a bit above your budget, so you may have to weigh that up.
Otherwise the Romisen RC-N3 is a great cheap light for well under your specified price, although a bit lower on the lumen's rating.
hopefully someone else will be able to give you some more useful advice
If you want to run your standard AA cells and you want a chance to try different beam profiles and user interfaces economically, you should get a Dereelight Javelin. It runs on 2 AA cells d has interchangeable P60 type light engine/reflector pill assemblies. There are many P60 style pills that should work in that light.
well im definatley gonna get a RC-N3 for general use but im also considering ordering this:
http://www.dealextreme.com/details.dx/sku.8537
any thoughts?
looks expensive for a q5 light, probably throws well but thats about it. i'd rather get this instead when its back in stock: http://www.dealextreme.com/details.dx/sku.32749
it'll be much brighter, costs less, smaller, looks cooler, probably won't throw as far, but will be more floody and produce more light overall.
any thoughts?
I have one of those. It's junk. Notice their picture looking straight into the front of the light- the emitter is way off center. That's because the reflector is thin plastic and does not have anything holding it in place inside the head.
The misalignment between the LED and reflector makes for one very ugly, distorted beam.
any thoughts?
If you want "way brighter" than your 100-200 lumens light then the RC-N3 is totally wrong... Buy the Skyray (if it gets back in stock) or any of the other R5-lights + two 18650 cells + "digital Li-ion charger" and you are still under $50.
Or if you really want way brighter then get the Trustfire TR-1200 for $45 but the batteries + charger will break your budget.
for that light ill go over my budget. what batteries should i get. i see a bunch on DX
Check out the Solarforce L2 ...
More power = MC-E or SSC P7 or possibly a multi LED ..
Check out Dealextreme.com and Kaidomain.com ... Just to get an idea ..
For your first purchase = Solarforce L2M [ 18650 body ] + CR123A extension ..
With low voltage drop in .
This will allow you to run , CR123A/RCR123A - 18650 - 17650 - or 2xAA
Then there is the L2i ...
With a low voltage pill , you can run , AAA - AA - 14400 - 14500 , 17500 , 18500 , 18650 and CR123A with a adapter .
In fact with some adaptive thinking , its a very nice battery host , if your looking for a sort of Survival type flashlight ...
I would recommend an itp A6 Polestar. It costs about 80 bucks, though you can get a 10% discount and free shipping at goinggear. This is a bit out of the budget, BUT...
It uses 6 rechargable AA batteries, which means you don't have to buy a 15-20 dollar charger and a couple of 8-10 dollar 18650 batteries.
The light is mostly floody though, but with 700 rated lumens on high, the hotspot should throw well enough to see at a decent distance. Plus it is awesome for lighting up an area around you. It has sensible medium and low modes also.
This is the cheapest way for you to get a high powered light (500+ lumens), as even with a cheapo DX P7 for 35 bucks you will still need the special batteries and charger.
The light itself is quite small relative to a maglite and fits nicely in your hand. It fits well into its holster that it comes with, or a pocket, or pack, since it has no 'assault bezel' or other stuff that sticks out.
Another ok option is a Romisen throw to flood light. They arent super bright, but run on CR123 or AAs. (I think 180 lumen rated max for the best one). However, you can adjust its options to go from a full flood (no hotspot), to a full throw (not much of a corona, only hotspot). It would be really cheap (25 bucks or less), and fairly useful.
A third option is a keychain light. An itp A1 EOS SS will set you back 32 bucks. It can use CR123s that you can get fairly easy, OR you can buy a RCR123 and charger for more voltage and brightness.
Witha normal CR123, you have a 2lumen, 30lumen, and 203 lumen modes! Really nice for a keychain light under 2.5 inches long! This makes is pretty bright and really handy. On a trip, you can just carry a 4 pack of CR123s in your backpack for plenty of runtime (as needed). The light is stainless steel and has a good reputation on this site. I have 2 A3s for gifts (came with my A6 polestar), and they are well made.
http://www.dealextreme.com/details.dx/sku.05790 TrustFire Protected 18650 Lithium Battery (2500mAh 2-Pack Blue)
http://www.dealextreme.com/details.dx/sku.06105 Digital Li-Ion 18650 Battery Charger
I've been happy with this combo. Please read the battery forum about LiIon batteries before purchasing.
I have the blue TrustFire 2500mAh batteries too and they work fine, but these should be even better at almost the same cost: http://www.dealextreme.com/details.dx/sku.20392
The TrustFire TR-1200 can use three 18650 cells so you may want two packs (or for using two and having two spares). I can also recommend that charger (or the equivalent Euro version).
I agree that the Trustfire 2400 is the best budget choice. I went with the AW 18650s because when it comes to battery safety, I didn't want to compromise.
If you decide to go with a DX solution, this is a decent way to go about it. That Trustfire is a beast though! Tons of light as you can see from teh video. It is a bit big though, however you have the extender tube option which is pretty cool.
The main problem is that DX lights can have some quality control issues. You might get a great one.... or you might not. This is why I would suggest the Polestar... it is pretty proven and you will have better luck with the warranty.
Another budget choice is the MG MX1, which is the only ohter high powered flashlight I can think of at a reasonable 60 dollar price.
