KingGlamis
Banned
While browsing lights at Qualitychinagoods.com I had to laugh at the description of the Ultrafire R1. Has anyone bought one of these yet?
Here's the funny description:
- Choose carefully and use a Genuine Philips Lumiled Luxeon Rebel LED bulb, the life-span is as long as 50000 hours, the strong light mode puts the lumen high in 135 lumen, collocate digit accuse of, in charge of, stablize luminance, effective to make battery power five luminance of type export oh!
- As you see this fund LED flashlight that make and become for the first time, you will be attracted dee you will be attracted deeply by its appearance.
- The lamp holder is that the arc is streamlined, some bars, for six mao model which feel extremely good, not merely esthetic, and more difficult landing.
- Use brand-new CR123A 1 battery, the time of shining can be as long as 21 hours (light luminance will be reduced with the electricity under the shimmer mode, become weak slowly while being extremely you will be attracted deeply by its appearance.
- Use brand-new CR123A 1 battery, the time of shining can be as long as 21 hours (light luminance will be reduced with the electricity under the shimmer mode, become weak slowly while being extremely bright), in addition, strengthening type reflector specially, the effective velocity of light is radiated and lighted centralizedly and taking in, almost perfect.
- The on-off mode of the power: The cranium is rotated, let lamp holder and battery be linked, can turn on the power easily; Having finished using, the cranium is rotated again in order to can close the power (lamp holder and space with 1 mm of light tube are very normal, so please don't need the excessive rotatory lamp holder, otherwise the battery will be damaged).
- 【On-off mode of the power, service time 】Light luminance will reduce with electricity, by very much on to weak slowly; If need to switch over the mode of using, please switch over rapidly in 2 seconds: A.Strong light - first section, 200 lumen of luminance, use for an hour (former factory offer the data). B.Weak light - second section, 50 lumen of luminance, use for 3 hours (former factory offer the data). C.Shimmer - the third section, 11 lumen of luminance, it is 21 small to use (former factory offer the data). D.Glisten fast - the fourth section. E.SOS cries for help the mode - fifth section
