Daekar
One of my buddies uses an Ultrastinger during his patrol duties - he likes the size of the light but wishes it had a bit more output. More runtime would be nice too, but he's pretty happy with the 60 minutes because he charges it every day and doesn't need it for longer periods at a time. I was thinking two possible upgrades:
1) Replace the stock SubC stick with better cells. I believe the stock cells are NiCad, so some 4000mAh or 4500mAh NiMH would be a nice upgrade. The only thing is, I'm afraid the charger will fry them because it discusses a "maintenence charge" in the *.pdf on the Streamlight website. Has anybody modded the AC charger or just ripped out the guts and replaced them...?
2) If the battery-upgrade worked, we'd want to increase output. I'm looking for a drop-in bulb solution that will work with the same reflector and voltage but draws somewhere in the neighborhood of 50%-80% more current @ 6V than the stock Ultrastinger bulb. Problem is, I can't find a replacement bulb on the SL website, so I don't even know what kind it is...
