Sold/Expired V2 Mag C Incan Driver-Soft Start & Multi-Brightness (available) Part 2
Status
Not open for further replies.
AW
Hong Kong
V2 Mag C Incan Driver-Soft Start & Multi-Brightness (Discontinued) Part 2
...continued from here.
Copied from original post for easy reference :
*** V2 Mag C Incan Driver Switch is now available ***
This new version has improved spec. over the previous version :
- Handles up to 100W lamp*
- Wide Input Voltage from 6V to 30V ( max. )*
- Soft Starting to prolong bulb life and ease the amperage draw on the batteries during power up
- 3 brightness level ( PWM controlled ) - 30% - 60% - 100%
- Last brightness setting memory ( default level - 30% )
- Flashing mode
- Simple UI ( click - ON ( low ) - Med - High - click & hold anytime - OFF - click & hold 1.5 seconds - Flashing )
- Full alum./brass housing to withstand the heat and better heat sinking
- Power efficiency 99%
- Low resistance
Price : $70.00 each ( Discontinued )
Shipping : $6.00 by Registered Mail
( $1.50 for additional unit )
PayPal : [email protected]
Introducing the Mag C Incan Driver with soft starting feature, 3 brightness settings and flashing mode. This driver assembly is a complete drop-in to replace the stock Mag C switch. The all metal switch housing is built with a high temp. KIU bi-pin socket and the driver board enclosed. Great for a Mag2C running the 5761/1111 for the smallest form factor with the highest output or Mag3C with a 1185. The multi-brightness function makes the Mag2C a perfect flashlight with a smooth low beam for everyday tasks while having a blinding 900+ lumen-on-demand standing by just couple clicks away. Runtime can be extended according to your brightness setting. The switch is made a few mm shorter than the stock switch so you can fit two LiIon C cells without the need of an extender ( you 'll need to cut the tail spring ). If you don't want to invest on the C cells, you can still use two protected 18650s in this setup with the 1111/7388 ( tail cap mod required ).
Specifications:
- Flashing mode
- Input voltage from 6V - 20V ( Vin = Vout )
- Drive bi-pin hotwire lamps up to 45W
- Low resistance
Here is couple video clips of how the driver works :
Incan Smart Driver Video Clip 1
Incan Smart Driver Video clip 2
Special Notes :
1) Works only with camless reflector
2) No Soft start for ' Flashing Mode '
3) The PCB mount push button has no momentary
4) Alum. reflector and glass lens required
Installation is simple. Remove the stock switch with a hex key ( 2mm ) and slide it out from the rear
Insert the Driver Switch in and align the switch button to the center. Use the same hex key to tighten the hex screw. You may want to move back and forth a couple times on the last turn to make sure the screw pierce through the anodizing for a good contact
Cut short the tail spring to fit the C cells
You can also adjust the socket height by either removing the two brass washers ( -2.5mm ) or by adding the included 6 pcs of 0.8mm steel washers ( +0.8 to +2.4mm ).
:paypal:
$76 V2 Mag C Incan Driver Switch
Thanks,
Jason
I would also like to purchase 3 of these to be shipped with the order. Please let me know how much more to send.
AW C Cell 3.7 volt Lithium Battery Adapter for Mag C Flashlight
:paypal: for 3 extenders....Thanks AW
PP sent for
1 - V2 Mag C Incan Driver - $76.00
2 - Mag C Extender Ring - $25.00
Thanks
BigusLightus,
xonid,
Order received. I 'll ship them out as soon as the C extenders arrive from the machine shop ( within couple days ).
Thanks!
AW
I'll take one $70.00 + $6.00 Shipping
PP sent:paypal:
Thanks,
Rich
1x MagC Incan Driver -- $70
Shipping -- $6
4x LiIon C Cells -- $88
Shipping -- $6
Total -- $170, paypal sent
Status
