Sold/Expired V2 Mag C Incan Driver-Soft Start & Multi-Brightness (available) Part 2
Status
Not open for further replies.
greenLED
La Tiquicia
AW, will this switch work in an early build 3C Mag? The light in question was built in the early 80's; it doesn't have the C in front of the serial number.
Also, has anybody tried 2x18650's in a 3C body and this driver?
:thanks:
senna94
Houston, Texas
:thanks:
I am currently running 2 X 18650s in a 2C body and they fit perfectly without the spring. Of course I had to sand down a piece of PVC pipe to make it fit perfectly so the 18650 do not rattle.
AW
Hong Kong
greenLED,
It won't fit the older Mag C with the retaining ring holding the switch. You can still install the switch without using the retaining ring but you 'll have to roll up some aluminium foil around the top portion of the switch to hold it in position.
greenLED
La Tiquicia
Thanks, Senna, but I'm wondering about the 3c body version of this build (not the 2c).
greenLED,
Thanks, AW. I'll think about it some more and will let you know. If I decide to do it, I'll probably need some more 18650s as well.
X_Marine
Houston, Tx
Hi AW,
I couldn't find these in your other links so wanted to be sure they are still available.
Many thanks
X/BillyD..
AW
Hong Kong
BigusLightus,
I 'll issue a refund. Please order when they are back in stock.
AW
Eddie-M
Hello AW, do you have any more of these available? I would like to buy at least two. Thanks.
Status
