Lux, I've not found silicone high strand count wire with a higher strand count. I really like using this stuff. I've wondered why they don't offer a 10 ga?
When you strip off some insulation on the 12 ga and then cut the remaining bare wires into your hand, the "fallout" on your hand feels like a soft powder - almost.
At McMaster-Carr, I found ultra-high strand count welding cable by Caroll. It's called Vu-Tron. There's battery cable, then there's welding cable and then there's Vu-Tron welding cable. In looking at the Ampacity charts, you can usually use a full 2 ga sizes smaller Vu-Tron cable to meet your current flow requirements as compared to their regular welding cable. A finer cable has a higher density cross-section - less air gap between the individual strands so it can carry a higher current load. This is what I used on my VSS-1 Tank light rig. Links don't seem to work to this page so go to McMastercarr.com and search for "Welding Cable". The Ampacity chart show the two types of cable in the same chart so it's easy to make a comparison. The Vu-Trom is extremely flexible cable.
