T45
Hi Don!
do you still make a SunDrop head for a Surefire E1 series body? like this one?
I believe all the SunDrop heads are E series compatible.
The 119 is so much better in terms of efficacy and luminous output that I have phased out the 083B.
In a post elsewhere, you opined that the 083B was unrivaled as to CRI while simultaneously being available at a higher color temperature than the x19 LEDs. I think you also estimated in another post that 60 lumens was the maximum output of an 083B. For an EDC light, that output level seems sufficient for most purposes, while the color temperature and extremely high CRI seem very, very appealing. So is the 083B simply unavailable anymore? Is it the need to limit the endless permutations or requests you receive? Or, if it is available (at a price), what LEs would the 083B compatible with, and how hard can it be driven?
Is it possible to order the Sundrop XR-U with a single AA Pak? I saw the option for the 2 AA pak; I was interested in a standard 3S setup with a single AA pak to run 1450 IMRs in. I like the slightly slimmer and longer bodies of 1450 lights, plus I use rechargeable batteries almost exclusively and the extra capacity of a 1450 over RCR123 would be a nice bonus.
Thanks Flashlight nut, that helped on the drive current.
I looked around the forum quite a bit but couldn't always find the figures.
I've got quite a few lights with the hi cri 219 so I kind of know what to expect in some ways.
So far settling on a 3V, 3S 660mA 119V LE. Unless of course I change my mind and go for a Haiku with the same LE.
.... I just wanted to get your opinion before I e-mail my order (hopefully tonight). I am deciding between the Haiku XM-L (3s) and the Sundrop Nichia 119v (3s). I know the basic differences, thanks to all of you, but have one last question. How far can the sundrop illuminate outdoors? The one outdoor beamshot I found showed a comparison and the sundrop didn't make it too far. I am not sure how far away the objects were in the distance....
The SunDrop (with Nichia emitter) is definitely more for close-in use. It is one of my absolute favorites, but I rarely use it for > 6' distances.
