hron61
2 pac?
I got the Haiku with the XP-G2 and the Sundrop with the 119v. I never had a light without a reflector before. The beam is so smooth and pleasant. It's very nice for close up work. Oddly enough the color rendering for both are very similar even though the 119v is HCRI and the XP-G2 is not. I took some photos to show this. I used the Surefire F04 filter on the HDS and Haiku to soften the hotspot.
HDS LE 250 (cool white) on medium with F04 Filter
[/URL][/IMG]![]()
Haiku XP-G2 on medium with F04 Filter
[/URL][/IMG]![]()
Sundrop HCRI 119v on medium
[/URL][/IMG]![]()
Can anyone tell me the size of the O rings used in the Sundrop XR-U? There's a thread for McGizmo o rings but it just has a question mark for the Sundrop. Just placing an order for spares.
Hello CPF,
I saw the garden beam shot comparisons and had the impression that the U-head delivered more of that brown corona than the original head. Is that so?
I have a 083 U version and use it with an f04 diffuser which --totally-- eliminates that brown circular artifact and makes the beam even wider, but if the original head has much less of the corona I would probably go for it.
thanks!
Thanks for your input! Do you happen to have some white wall beamshots of the original sundrop?The original SD setup is amazing.
Dear Don, thanks much for your response.
Yes, I am aware of that clearance issue and I am considering the original non-U head specifically for the nichia 083 based LE that I have now in an XR-U head. I like this 083 LED very much and I just wonder if a non-U head would provide a more artifact free wide beam for this particular LED.
I am seriously considering an empty mule head too, but not for a neutral white LED. I have tried a few LEDs and my best candidate for a mule type beam is 3000K XPL.... The original SD head will have less of an artifact than the U head as well as a bit greater angle of coverage as I recall. Have you considered getting an empty Mule head as alternate host for the 083 LE?
Hey Don!
2 quick questions
1.) Do you still make the Sundrop XR-U with a Nichia 083? From what I've read that one seems pretty legendary as far as "sun light esque" quality
1b.) If not is the 119 the highest CRI you offer/best comparable?
if so...
2.) Any guestimate on when I'll be able to order one w/the whole 3S issue going on as I want a Sundrop XR-U with just a cr-123 battery.
Thanks!
Nichia 083 has not been available for awhile now and yes the 119V is Don's highest CRI offering.
