Maha MH-C9000 charge termination, firmware update
There were issues with charge termination in the Maha MH-C9000 charger, when it was first issued in Sept. 2006. Maha changed their firmware in March 2007 (serial # starts with 0G).
I purchased one recently and have so far only used the break-in mode...in which the charge terminates according to time. One of my 2500 mAh Energizer batteries (new) is problematic in that it only has recorded capacities of 1925, 1888, and 1848 mAh after running the break-in mode three times.
So I tried to rejuvenate the battery by cycling: charge rate 900 mA (0.36C), discharge rate of 500 mA (0.2C), 10 cycles.
Result: Cycle one ran overnight and was not finished in the morning...when subtracting the recorded discharge time and the hour of rest, the battery must have been charged for 5 hours. That is, the battery did not produce enough heat, negative voltage, in order to terminate charging and was pumped full.
Sounds familiar. In the absence of other testing, I wonder whether the charger has still issues or whether the battery is to blame.
