I don't post on CPF, as usually by the time I get to a post I can relate to, everything useful has been said...
I've got a Leef 3 x 18650 body, running AW cells and driving a MN61 in a SF turbo head. I built it up for an experiment to get a long running, rugged, bright light. Something I could rely on for use in the Mountains.
Well it works and it sure is bright - the same as my M6 - so 500 lumens+ out the front!!! Current draw is 2.8A on fresh cells, straight off the charger at 4.2v. No messing here with rested cells!
I've been running it for a few weeks now, with no blown LA yet. I tend to use the light for constant on periods of 10 - 20 minutes at a time and I get a runtime of 40 minutes to 45 minutes, which is just fine!
I've tried running a MN60 as well and this works really well also. Noticably brighter than a MN16, 1.7A current draw and a runtime of 70 minutes...
Both set-ups are really white, not suprising they are a bit overdriven! But these Surefire LA are tough...
I'm quite happy to rely on the light for extended running, in the high mountains at night. Something I would never do with a ROP or a MAG85.
Hope this helps.
By the way, I really want Lumens Factory to make a 700 Lumen 13V M-series compatible LA as well. In an M6 or my 3x18650, or better still in a up and coming Leef 3 x 'C cell' M series body, it will be a stunning set-up - between the MN60 and MN61 and with 1 hour+ runtime - 1.5 hours with C-cells.
Come on
Mark@LF you know it makes sense!
