DM51
This is a beautiful-looking light, made up from 3x 26700 BigLeef body units, BigLeef tailcap, BigLeef Mag-neck, and a Fivemega FM3V-2 turbo-head. The quality of all the components is superb.
Note how the 'tear-drop' pattern on the BigLeef body complements the fluting on the Fivemega turbo-head. The gray color is a very good match too.
The one jarring note is the neck module, which is black, not gray. For some reason which totally baffles me, Leef did not produce any gray ones. (Where do I find that small round yellow cartoon face thing scratching its head in perplexity, so I can insert it here?)
This is a BIG light. Here it is compared in size to a Surefire M6. It makes the M6 look pretty small, which of course it isn't.
However at this stage it is still EMPTY.
This brings me to question #1: what should I put in it? The body would take either 3x A123 cells, or 3x Emoli, or maybe 4x AW 'C' Li-Ion cells. The A123 or Emoli options sound good, as either of these could run a high-current bulb.
I also have a couple more of these 26700 BigLeef body modules on the way from Lighthound, so it could be a 4x 26700, or even a 5x! This could turn into a pretty serious light. What combinations would be best for it?
Question #2 is where it all gets a bit technical (for me, anyway). Here is the inside of the neck:
Somehow, a bulb-holder (etc) goes in there. The question is, which one? Kiu? What do I need? Has anyone else fitted out one of these necks, and if so, how did you do it?
Advice will be gratefully received!
