What to build with 3 IMR C cells????? brightest!
bigchelis
Prunedale, CA
Hi all,
Now that I been putting together a couple of ROP's I want to see how far I can push it with the stock switch and no soft-start.
I have a spare 2D Mag and with the tail cap short spring it fits 3 IMR C cells perfectly. I already have 2.5in Throwmaster and KD reflectors along with UCL lens from lighthound.com and now want the most bulb lumens possible.
My buddy has a 3D that he wants to give me for a 4 IMR C cell build too, but I want to keep the stock mag switch and no soft-start.
All I need is the fivemega kit to be able to use bulbs like WA1185 ect...., so I will be getting this tommorrow.
I looked at Lux most powerfull builds and some of those 100watt monsters seem to have battery packs and aftermarket switches, but I want to build something the average Jose can do:duh2:
Thanks,
Jose
The Fivemega 1909 bulb seems to be designed for 3 IMR cells, but you have to buy it with one of fivemega's hosts.
I apologize in advance if this is a dumb question, but since I just purchased the fivemega G4 bin and his FM 1909 for 3 IMR C cell duty and he adviced me on this:
"FM1909 will work with 3x26500 IMRs but resistance fix needed if M*g is the host. "
I don't know how to add resistance to the tail. Is there a thread or link somewhere that I can read up on this?
Thanks,
bigC
Not add resistance, reduce it.
The main 2 ways are to add some copper braid to the tail spring (solder wick works well), providing a path from the top to the bottom, letting the current bypass the spring. You can also add some to the top spring inside the bulb pedestal, I'll see if I can dig up a link. Also some DeOxit inside the contacts of the switch really help.
http://candlepowerforums.com/vb/showthread.php?t=130965
http://homepage.mac.com/rouses/circuits/PhotoAlbum289.html
You probably don't need to go to the trouble of completely hard wiring the switch, just doing the 2 spring mods and deoxit inside the switch contacts will make a big difference.
Cheers,
Nova
You are going to love this mod!:devil::devil: I am running the same set-up as you are (2.5 Throwmaster, ) and it is a beautiful beam. Enjoy Jose!
Thank you all for the help. The links were very informative and helpfull too.
Off I go to Radio Shack to seek out this infamous cooper braided wire:naughty:
bigC
bigC
When your out also grap some lye drain cleaner the gel type to Deanodize the tailcap. Put about 1/4" iside the bottom of the tailcap. It saves you a lot of sanding and the final results looks clean.
The FM1909 is mythical magical beast. My favorite incandescent bulb period. Highly recommended. The easiest way I know to get one is to order a bi-pin adapter from FM and score a bulb at the same time. See this thread. http://www.candlepowerforums.com/vb/showthread.php?t=179891. The bi-pin adapters are an excellent product also.
Happy Mods!
Happy Mods!
Thanks,
That is exactly what I did:D:D
Next week I will take some beamshoots to compare the ROP H vs. Fivemega bulb.
I will also try that Drain fluid to remove the anodizing too.
bigC
