Whats the notch in the 6P?
buickid
Capt. Cook, Hawaii
Theres a small notch at the tail end cap of the light, and a corresponding one on the tail cap. I assume its some kind of alignment thing, but I'm wondering what exactly its intent is. I bought my 6P used, so I don't have a manual to refer to. :eek:oo:
Generally, when you tighten the tailcap all the way down, then back it off to the point where the notches align, the light will not activate from pressure on the body of the tailcap, but will from pressing the tailcap switch button. It's technically a good medium setpoint, because it's about halfway between locked out, and constant on. On some lights you will still have to back it off a little to keep from activating by pressure on the tailcap.
It does make it convenient to index the switch from the lockout position for use without actually turning it on. SF also has polymer holsters that can carry their lights bezel up, and downward pressure on the light shouldn't accidentally active it with the notches aligned or slightly past that point, but it will be ready to use when the switch is depressed.
I find it most useful on my new L1, which has a notch and a circle in the middle of the tailcap body instead of a corresponding notch. When they're lined up, there's no accidental activation from pressure on the tail(I got one of those tailcap shrouds, so this works beautifully), plus the switch is just a quarter turn from constant on in low mode.
I think my old E2e lined up perfectly. Not sure that any of my C or M series lights have. Seems like they're always just a little bit off.
It doesn't have to line up to serve as a reference point.
But it does make it simple and intuitive if it does, especially when you own several versions of the same light. Just one of those perfectionist things I guess.
My experience has been that the point where the notches line up is a point where the push-for-on mode is working as intended. Rotate the tailcap a full turn again counterclockwise to that same position, and it is locked out well from accidental activation.
I think it's a neat feature but not totally necessary.
This is exactly what I observe on my lights. I always keep the light in the aligned position.
My experience has been that the point where the notches line up is a point where the push-for-on mode is working as intended. Rotate the tailcap a full turn again counterclockwise to that same position, and it is locked out well from accidental activation. [snip]
I think mdocod got it right, that seems like what it does on mine, at least with the SLF 1-cell extender on anyway. When I get a 17670 I'll test it out w/o extender. :D
Its for how many Mag's its killed!
Its part of there initiation you know...
