PhotonFanatic
Some WIP photos for a couple of lights that I am making out of two-color Mokume Gane. The goal will be to have
these flame colored and then either coated to protect the colors, or possibly colored, then turned down to expose
the bright silver. I'll see what I get as I go along. Here's the last flame colored light that I made using
Mokume Gane:
Posted 5/19/10:
So, I'm using the same basic design--a modification of my Killer AAA Light--these are about 14-15mm in diameter
and about 53-55mm long and use a 5mm LED driven at 90mA and powered by an eneloop rechargeable AAA battery. Only
this time, I'm not going to make the light look quite so old--nor am I going to machine any grooves in the
light--I intend to let the natural twist pattern speak for itself more. Here are the two bodies that I've made,
with the heads screwed down onto the bodies:
And here's a close=up of the head, showing the boring need for the LED and the driver board:
I am etching these so that there is considerable relief between the two surfaces, as I might want to turn the
light down as one of the final finishing operations. After etching:
Another photo that shows the depth of the etch a bit better:
Update:
I torched the light, trying to be a bit more patient this time, so that I wouldn't go past some of the interesting colors. I decided to stop quite early this time,
when I had a red/violet color:
And a close-up:
Then it was back to the lathe to skim the oxides off the nickel silver, leaving a highly contrasted light:
Mokume Gane:
Posted 5/19/10:
Update:
And a close-up:
