tino_ale
Hi all,
As far as I know, most of the aluminium machined flashlights are made from 6061 alloy... sometimes 6061-T6 which is heat treated.
While I totally understand this choice for low/middle priced flashlights, I am sometimes surprised that higher end models are not made from something more solid.
Expensive models and/or expensive custom torches are most of the time 6061 alloy too. You get 6061 T-6 if you're lucky. Don't get me wrong, 6061-T6 has good properties, but it's certainly not the best you can get. But when I see flashlights with to-be-released led bins, super-hyper-efficient drivers, 2mm thick (or more) AR coated sapphire glass, top notch o-rings, silver coated springs... in the middle of all these refinements well I feel that 6061 alloy, even T6, is kind of at the low end of the material choice. For example, I'm surprised to see that ARCmania $800 SF V, a zero-compromise high end and refined limited model, is machined from 6061-T6 only. Just an example.
You can go for titanium, but the offering is very limited, and prices are so much higher. Titanium has it's niche.
I would like to see something in between. It's perfectly doable with 7075-T6 alloy for example. It is something like 40% higher in tensile and yield strenght compared to 6061-T6. 300% and 700% higher if you compare to simple 6061. Upgrading from 6061-T6 to 7075-T6 would be a significant change in terms of dings/scratch/bend/breakage resistance.
I think the Tiablos are made from 7075 alloy, but I don't even know if there are flashlights out there that are made from 7075-T6. 7075 is actually a little less strong than 6061-T6.
So... I am the only one here?? I have that feeling that people are extremely picky about led bins (a P4 WC cree is kinda outdated as of today...), reflectors, glass and many other things but not the alloy used. Why? Manufacturer advertise over and over that alloy used is "aerospace aluminium"... that is 6061. Do people think when they read "aerospace" it's the very best you can get?
Thanks for your thoughts.
Cheers
Cheers
