Here is my short review of the
XJC B-8 Super Bright CREE P4 LED Flashlight Silver(1xAA)
I was looking for a flashlight that has the following specs:
- round shape (especially no sharp bezel)
- powered by 1 AA
- GID-tailcap
- glas lens
- OP aluminium reflector
First impression: Great finish, very durable coating, very handy, good machining and manufacturing, great switch (easy + smooth clicking). Not the brightest flashlight around, but sufficient for the most applications. (Typical brightness for a 1xAA flashlight).
I ordered two flashlights. They both have little differences regarding tint + power consumptions(=brightness). The brighter one draws about 1.5 Ampere and has a little bit blueish tint. The other one draws about 1.8 Ampere and has a little bit greenish tint. (Measured using NiMH. Alkalines draw around 0.2 Amps less.)
Here are some pics:
Regarding the sixth picture: If you don't like the (typical CREE) ringy beam , you can use a washer between reflector and LED. Then you will get a smoother beam (see 7th pic - left original - right modded). The brightness difference is because of the use of a depleted NiMh in the right lamp.
(This shot was made on a yellow painted wall!!!)
The dimensions of the boards are: LED-board 16mm, driver-board 17mm.
Bottom line: I really like this flashlight. The spelling "Supet" instead of "Super" makes this flashlight even more special. :laughing:
P.S. If you want to get the "premium" version of this light (shiny silver, 5 Modes, Q5 LED), then go to Shiningbeam's shop: http://www.shiningbeam.com/servlet/the-59/MF-DA1-Cree-Q5/Detail - he has a black Q5 version, too.
- powered by 1 AA
- GID-tailcap
- glas lens
Here are some pics:
