My first experience with Thrunite was only just over a week ago with the new TN12 neutral white. I even ordered a new Nitecore charger and some Olight 3400 batteries at the same time as I ordered the Thrunite to be sure I would be good to go. Sadly the TN12 had an issue immediately and would only turn on about half the time I pressed the button. The issue seemed to be only in the tailcap switch as the mode switch worked fine. Having some experience with some cheaper 501, 502b type flashlights, I've seen how loose parts especially in the tail cap can cause weird issues like this. I checked inside the tail cap and it was screwed in tight. Anyway, the times it did work I was happy with the output, tint, and levels so I returned that one for another. Thank you Amazon Prime. The second TN12 I received worked perfectly so I was happy. It's impressive that for the size of this thing it can put out a ton of light and the option for neutral white is really important to me. I immediately ordered a TN11s v2 neutral white and that arrived and worked without issue. I really love the throw on this one and plan to get a lot use out of it.
Though I don't have a ton of flashlights to compare these to, I have had some serious bicycle lights from, Cygolite, Niterider, Gloworm x2's, and even own two high end Lupine lights so I know a bit about lights. I've been night riding since the early 90's and I've gone from halogens, to HID, to LED and have seen the advantages and disadvantages in each. The biggest issue I've had with Hid's and Led's are with the tint being on the cool side and flatten the terrain a bit when cycling in the woods whereas I'm hoping neutral white will bring out the trail detail better and make it look more inviting at the same time. If the snow ever goes away here I can test these lights out on the trail and see if the neutral gives me more of what I want out of a light. Right now I am using the TN12 as my EDC and taking the TN11s for anything that calls for more throw. So as long as these Thrunites stand the test of time I can see myself buying more of them down road. I really like the way they are packaged too and would make for excellent gifts.
