Couple of interesting 1/2watt lights from AdvancedMart.com -
Chromed brass .5 Watt Pocket sized LED keychain flashlight (LED-050CR2) 1 x CR2
Chromed brass .5 Watt Pocket sized LED keychain flashlight (LED-050CR123) 1 x CR123A
or available as a pair at even lower price -
Chromed brass .5 Watt LED keychain flashlight Combo (LED-050CR2 & LED-050CR123)
@ just under $20 for the pair. Using single Lithium batteries - CR2 and CR123 respectively.
Size comparison -
Both being chromed brass - they feel pretty substantial/heavy for the size. Both have reverse clickies. Both make very good electrical contacts as both bodies are actually fully electrically conductive, inside and outside.
Heads view -
Supplied with battery and pouch -
Both lights are supposed to be compatible with rechargeable Li-Ion batteries.
(I only have RCR123 sized 3.6-3.7V rechargeable Li-Ion batteries)
Compared with each other both on regular non-rechargeable CR batteries -
The CR2 version seems brightrer and with a nicer tint.
CR2 compared to used RCR123 3.6V rechargeable -
Used RCR123 seems to output about the same level as the non-rechargeable CR123 - neither are as bright as the CR2 version.
CR2 compared to Freshly charged RCR123 -
Now here's a surprise - a RCR123 freshly off the charger - actually seems to give a dimmer output than either the non-rechargeable CR123 or the used RCR123.......!
Here are the current draw measurements -
CR123A (non-rechargeable) - 3.07V - 100-110mA
Used RCR123 - 3.82V - 120mA
Freshly charged RCR123 - 4.06V - 30mA on 10A scale -
BUT 107mA on 200mA scale!!!! (and looked brighter)
Compared to CR2 version
CR2 (supplied Tianqiu) - 2.94V 120mA
CR2 (Panasonic) - 2.97V 120mA.
It has been posted that the 200mA scale would have an in-line resistor -
So I would have thought the light should be even dimmer and show a lower current draw....?
My speculation - freshly off the charger the RCR123 measured some 4.07V open-circuit. This might be too high for the light and the circuit may have reduced the current for protection. However using the 200mA scale which put some additional resistance in-line may have reduced the power draw enough to allow the light to operate normally(?) - this is just a guess on my part.
Either way the CR123 version was dimmer than I expected and there was not an attendent increase in brightness when using 3.6V rechargeable RCR123 - the light stayed roughly at the same level - at least on my sample.
CR2 version vs. 0.5w 1AA - AdvancedMart LED-005S
Very similar brightness levels, hotspot and side-spill corona sizes -
but the CR2 has a nicer tint - not really that noticable in practice - but definitely shows in a side-by-side beamshot.
OK, how nice a tint? -
CR2 version compared to a 1watt Luxeon Fenix L1 v2.5 (Non-Premium)
Obviously NOT as bright - but SURPRISE! - I think this AdvancedMart 0.5watt CR2 version actually has a nicer tint than the highly regarded Fenix L1 v2.5 - amazing....
CR2 version vs. Nuwai 0.5w 1AAA (TM-310H)
Comparable brightness - but, not surprisingly, the Nuwai 1/2watt is noticably Bluer.
CR2 version vs. 8LED 1AA "Xnova" New
Xnova 8 new seems to have slightly brighter large flood-y hotspot - but these lights are pretty comparable.
The CR2 version is advertized and has been tested to give a runtime of about 5.5 - 6+ hours on a single regular CR2.
The CR123 version was a bit of a disappointment to me - because it was dimmer AND the advertized and tested runtimes were still about 6 hours - no better than the lower capacity CR2.
Wheras I am pretty impressed with the CR2 version with comparable brightness to other 1/2watts of this world and a tint on my sample of one that may be better than the highly regarded 1 watt Luxeon Fenix L1 v2.5 ! -
that I think is actually pretty amazing for a mere $10 light!
Size comparison -
Heads view -
