SF L1 has 3 generations. Most of difference can be tell by bezel heads.
Gen1/ no scallop on bezel. Looks similar to A2 bezel. 1W LED 50hours on low runtime. traditional pull out box. In silver, huge box. release before 2004
Gen2/ with scallop on bezel. Looks similar to A2 bezel. 1W LED 50hours on low runtime. New blister packaging. similar to current packaging. release before 2004
Gen3 (current gen)/ Brand new design bezel. Looks similar to E1L, E2L, L2 kinda modern looking bezel. 3W LED 90hours on low runtime. release after 2004
If on ebay, you can definately tell the current gen and gen1. simply, box just looks so much different, so does bezel. to distinguish gen2 or gen3, cuz of the packaging is a bit hard to tell. Ask them to show you actual product picture, you can tell easily by bezel. You can also ask them if the light is 1W LED or 3W LED.....but i do found some sellers have no clue what they have in hand.
Current gen has more focus light, no side spill, throw much longer, much longer run time than older gen.
Hope that helps.
