Are you guys in 20th century? 11W is weak. Mine is 1500 watt.
13W, 17W, 20W? Why settle for these sub-par junk using fake Luxeon emitters when you can get a one and half kilowatt ten Luxeon light made using REAL Luxeon lamps?
Runtime: Approximately 3.5 hours on ten, 12V 50Ah in series. DC 120V.
Do not block air flow to 1460W resistor module.
With cheap counterfeit, you never know what the wattage means. Unlike those junk, we guarantee that our unit will use and dissipate 5120 BTU/hr 1300kCal/hr into the air. In fact we are so sure our unit will perform to its spec that we recommend a minimum of 7,500 BTU air conditioning capacity for the room to maintain comfortable temperature.
Fan cooling on resistor module recommended to keep it from getting too hot to touch. Here's a prototype. Once there's enough interest, I will actually have the ten Luxeon module made.
Reverse Polarity protection diode included in price (not pictured).
