carrot
I made myself a Fenix pocketclip with some pliers and 16-gauge wire. It's not terribly secure, but it fits and doesn't seem like it is likely to come off by accident either. It's tight and fairly springy. Great for pockets, not so for belts. I also managed to scrape the finish of the Fenix in the process.
I'd definitely recommend this if you're looking for a simple pocketclip so that your Fenix doesn't fall to the bottom of your pockets. You might scratch the finish, as I did, though.
I do not intend on selling these!
In this picture, you can see my two Gerber multi-pliers and wirecutters. And the Fenix with the "finished" pocketclip.
Version 2
Using one of those metal rings used on tubing you tighten with a screw, I improved the design.. It is now very secure.
Version 2
