I do not know is it a right place to post this message however if you are dealing with High power LED you should check this page. Custom designs are welcome and the prices are as low as 13.99 USD including High Power LED.
http://www.acg-ltd.com/acg_project_4_en.html
That page is the only english part in our website more will come soon but if you want to ask more... msn : [email protected]
LED Module With Integrated Constant Current Driver
Specifications:
- High power Luxeon I, III and K2 leds
- Outstanding drive efficiency up to 95%
- No resistors to limit the current, thus very low heat generated at the circuit
- Reverse polarity protection (+ and - does not matter)
- Very small dimensions and weight, ultra thin, highly reliable with SMT technology
- Available in White / red / blue / royal blue / green / red-orange / amber / warm white leds attached on FR4 or Aluminum core PCB for superior heat dissipation
- Wide input range 8-30V (custom designs are welcome)
- Drives up to 4 leds (same input can drive 1,2,3 or 4 leds in series)
- 3 standard drive options : 350mA / 700mA / 1000mA
- Custom demands with PWM dimming, higher voltage and current are welcome
Sincerely
Specifications:
Sincerely
