I've had a U2 for close to a year and have been using CR123As. However, after reading all of the great posts about using 18650 I decided to remove the black plastic tube from the inside of mine before I purchase my rechargable batteries and charger. A search on previous posts gave several excellent ideas, but none have worked for me so far. At this point I'm on the verge of giving up because I don't want to damage my U2 anymore than I already have. But, I sure would like to use 18650s.
I disconnected the head and tail switch before performing the following:
1. First tried to lightly clamping the body into a vise and tapping the black sleeve with a small screwdriver (from head-end down toward tail-end). All this accomplished was scratching and cutting the sleeve near the top.
2. Tried freezing for 15 min. and then repeating step 1. Repeated this whole process five times.
3. Using a small screwdriver tried to pry a small opening in the lip-end between the sleeve and the body and poured Acetone in between and let it sit for several minutes. Then repeated step 1 again.
4. Went to Wal Mart in search of the "bottle capper" with no success.
Please help!
Thanks in advance
Please help!
Thanks in advance
