Dear troubled user
The problem you are experiencing is a very common complaint we at Men's Life Corp. run into all the time. Many people upgrade from Girlfriend 7.0 to Wife 1.0 thinking it is simply a Utlities and Entertainment module upgrade. Wife 1.0 however is an OPERATING SYSTEM and was designed by its creator to take over and run everything. It is IMPOSSIBLE to purge or uninstall the program files completely once it is installed. You cannot go back to girlfriend 7.0 afer upgrading to Wife 1.0. Look at your Wife 1.0 manual under Warnings - Alimoy - Child Support and you will see that even if you redo your system and upgrade to Girlfriend 8.0 some files and system resources are still taken by Wife 1.0.
We simply recomennd that you get used to working with Wife 1.0 and try hard on improving the situation. We highly recomend that you install and use the background application Yes Dear 1.32 to help alleviate software conflicts.
It is avisable to utilize the command C:/Appologize because eventually you will have to use the Appologize command the situation will not correct itself before doing so.
Wife 1.0 is a great program but tends to be high maintenance. Wife 1.0 comes with several support programs , they are Clean and Sweep 3.0, Cooking 1.5, and Do Bills. Be careful how often you make Wife 1.0 utilize these programs without support as it has the progams Nag Nag 9.5 and Honey Do List 4.7 that it uses quite often and if utilized as often as Wife 1.0 utlizes the preveious named programs a system error will occur. In this case the only solution are programs Flowers 2.1 and Diamonds 5.0 used immediately and liberally.
WARNING: Do NOT under any circumstance install Secretary with Short Skirt 3.3. This application is NOT supported by Wife 1.0 and will cause immediate and irrevocable damage to the operating system. It may even crash your system completely.
Hope this helps and best of luck,
Tech Support
Tech Support
