During CPF blackout I sent these reflectors for metalizing and I received them the other day. When I left them I asked if they can make them to resemble an orange peel, but it seems they eat a different kind of orange than me
The result is an over stipple, or a more apropiate term a freezed look:
Mcr38 vs CREEflector 38
Here is a comparation with an aleph3
Some light is scaping thru the metalized finish, this wont happen on production items since they will be made in metal.
Today while chatting with other cpfer I tried to explain the term "wall of light" but failed, because its difficult to compare a flood beam. So after thinking about how to show it I came up with this idea.
Use another flood light: a stock CR2ion, the "wall of light" reflector with a cree XR-E driven at 700mA and a static object.
Please keep in mind that im comparing two different beasts, so its not a race to see which one is better, but a method to show the flood magnitude of the CREEflector
I arranged both illumination devices so they hit the static objects from a different angle so the main beam of one kills the shadow of the other (am I being clear :thinking
The distance from the wall to the flashlight was exactly 3.5meters (11.5ft)
Here is the setup:
And here is the beamshot (click on image for full size pic)
Now, open the big picture and take a look on the shadows of the object over the table and you can see how the CREEflector outshines by a factor of many X the CR2ion.
Then look at the lamp shadows, the difference is even more notorious which comes at no surprise given the diameter of the CR2ion reflector
And finally for your reference that table is 1.35meters wide (4.9ft), that should give you an idea of the flood size.
Well, IMHO this is better than trying to explain with just words what a wall of light means.
BTW, I made 3 more prototypes on my router and left them on the metalizer today, this time I asked them to sandblast one then mirror finish, and the other two to make them mirror finish without any other treatment.
Hope you all like it
Pablo
