4sevens
I'm copying and pasting exactly what they have sent me here:
(original size here: PICT
Fenix P1D CE's Beam Testing
The Fenix P1D CE's beam situation is as below:
1. It is awesome in the central focusing spill, really bright with flawless beamshot and there are no rings.
2. The floodlight is also bright. It is both good for the central beam's long shot and close quarters' lighting.
As per the "dark ring" in the P1D CE's beam reflected back from some of our Fenix P1D CE's users, we test it scientifically with the conclusion as below (Please refer the attached pictures for more data):
The Cree LED is greatly different from Luxeon LED in lighting angle, brightness distribution and even throws aspects. We could easily see these differences such as uneven brightness and tints from a naked Cree LED.
As a result of this, there is a "dark ring" in the P1D CE's beam while you shoot it on the snow-white wall. As a matter of fact, it is just a visual illusion as per our testing and objective analysis. In according to the test, the flux from the center spot increased gradually, but that growth will slow down when close to the center spot. Meanwhile, the Cree LED's tint changes slightly and deceives our eyes and it forms a beingless ring.
In addition, our current optical design is mainly safeguarding the P1D CE to have strongest light-condensing ability and maximum lumens. If we lower our requesting standard in light focusing, we could reduce this ringy visual illusion. But we must carry on further evaluation to test if this is good for the life lighting.
**4sevens note: I could not find a dip in lux readings dispite seeing
the ring. However I think Fenix hit the nail on the head about the
tint variation causing the illusion.
