I am after a single cell 123A LED light for a police officer friend. This light is intended as a backup. Living in the UK, I have narrowed the choice down to 2, Inova's T1 and Ledwave's X11. Any thoughts on these.
My P1D-CE has just arrived and I would recommend that quite strongly if it is to be a backup light (where a click switch isn't required). The older P1 is a bit cheaper and still a really good torch.
Have no fear in ordering from David at www.fenix-store.com his service is absolutely excellent and the free delivery from the States only normally takes a few days.
I'm a P.O. I always carry two lights, and use a Fenix L2P mostly, which I find excellent for dark alleyways and buildings where the lights are out. I can recommend it. I know you have specified a 123a light, so maybe some of their range will suit. I also have a nuwai q3, but it's not used now I have the fenix. The price of batteries here, you know....
Is the recipient going to be good at keeping rechargeables full, or will they be using primaries? If the latter (and the light will see frequent use), definately go with sideswipe's suggestion of a AA light (the Fenix L1T is still quite small).
Check out the Lumapower D-Mini. It's a single 123A light that takes RCR123 for savings, includes both clicky and tactical on/off options for one-hand operation, and is very bright (Cree!) with superb throw - it should be ideal for police work.
The VB-16 is another good one - it takes either two 123's or a single rechargeable 18650, is slender and easy to pocket, is bright with good throw, and has a terrific UI.
Thank you to everyone who has replied. Finally found a Fenix stockist in the UK. The L1T is looking very interesting as it runs on an AA battery. What type of beam does this torch have, spot or flood. Recommended ?
I'm afraid I can't help with the beam on the L1T, the beam on the L1P is a nice spot with plenty of spill. Out of interest, which UK supplier of Fenix have you found?
It might be worth looking at a US supplier, I hear good things about Lighthound etc on here. £30 plus p+P seems a bit steep, you might find an import pays. I was lucky enough to pick up a L2p in here from someone in the UK.
