I appreciate your time. Back to the E series. The tailcap differences between the early and current Executives, and the E2D...so they would be described by the body they came attached to? no model number?
Back in the day, there was the E1 and E2, in HA, BK and GM (Gun Metal).
These went through a few smaller changes before SureFire replaced them with the Elite version: E1e and E2e.
The changes (Improvements of the Elite)
New LockOut TailCap.
New bezel with Pyrex window (instead of Lexan), Anti-roll hexagonal style.
New bodies with new PocketClip (replaces the one on the bezel).
SureFire at about this time released the LockOut TailCaps so that people could update their E1 and E2 flashlights
Z52 LockOut TailCap - E Series - HA
Z53 LockOut TailCap - E Series - GM/SG
Z54 LockOut TailCap - E Series - BK
Note that SureFire changed the name of the finish they called GM (Gun Metal) to SG (Satin Grey) which I guess is a more appropriate description for what I'd call metallic silver...
The TailCap prior to the LockOut version was not sealed - the switch contact was not retained and could be removed, and the rubber switch boot could also be removed. Now, the LockOut version sealed the rubber switch boot and retained the switch contact to restrict its travel (thus enabling the switch contact to be rotated clear of the body contact surface and disable the switch).
I would be interested in more info on the Z14 and Z31 if you have the time or could point me to a older thread. Thanks.
I don't know (and nobody at SureFire seems to really know either since it was such a long time ago) what the difference between the Z14 and Z31. My guess is that the difference was because SureFire updated the profile of the rubber switch boot. Indeed, these higher profile, more aggressively knurled switch boots were included with certain other accessories.
This is the info I have:
Z14 TailCap (Classic) Three parts (for Standard Bodies)
Z31 TailCap Group (for Standard Bodies)
Also, there was a
Z23 TailCap Diaphragm Sealed (for Standard Bodies)
which had the rubber switch boot sealed.
Then there was the Z41 - the current LockOut TailCap design that has been sealed for water-resistance.
Does this help?
Al
