digitaldave
- Joined
- Jun 18, 2008
- Messages
- 164
Dear all,
Now I've got my head around how the L1 UI works (turns out it's much simpler than I'd initially thought), I'm left with a problem... When I thought the L1 was awkward to use, I was leaning massively towards the E1L, but now I know the L1 is easy to use, it's not so cut and dried... I see the pros and cons as follows:
E1L:
Pros
Smaller for easy pocketability
Much longer runtimes - are the SF web site run times reasonably accurate?
Low setting is lower - but will it's 3 lumens be quite close to the L1's 10 in real use?
Cons
High setting is lower - although I'm sure someone has said it's actually not that different to the L1's high.
L1
Pros
High is higher than the E1L (although may actually be similar in real world).
UI is simpler (although the E1L isn't rocket science either) - gives instant access to high or low mode as needed without having to switch between modes.
Cons
Costs more.
Run times are much lower.
Slightly larger.
Neutral points
Both use the same number of cells.
Both can make use of the beam diffuser for more flood.
The UI issue isn't really an issue as such, in that they both seem simple to use, but in different ways. I looked at the E1B as well, but I'm not keen on the fact that it's permanently set to high first - I suspect that for me, low would bet more use, so having low first would be preferable.
One other issue that's been mentioned in other threads is that the E1L has a clicky tail cap, whereas the L1 has a twisty, and it's been said that the clicky is more likely to fail. Whilst I don't doubt that the clicky is more likely to fail, is that actually going to be an issue in real world use? Have there been many reports of failed clicky switches?
Finally, what about using rechargeables? Is that possible with stock versions of either light? And if it is possible, should I just stick with primaries for the much longer run times?
So, I think that's all I can think of. What do you guys think?
Thanks,
Dave.
E1L:
Pros
Cons
L1
Pros
Cons
Costs more.
Slightly larger.
Neutral points
Thanks,
Dave.
