I just bought this one,
Photon Digital Dual 2 Headlight, from Nashbar. I think I paid a little less than the current price. It has, if I'm not mistaken, a PR2 base halogen bulb. Nashbar says it's a 2.25 watter.
I don't know who makes it. It's branded as a Nashbar "Photon," with a Nashbar "n" logo painted just above the LEDs on the lens. Nashbar sells other lights under the Photon name as well.
The hot spot is very tight and it suffers the effects of a ribbed lens. On the bike, you can't see around curves at all, so I was pretty disappointed when I took my first night ride with it. Also, its water resistance is laughable, so if you get caught in the rain, you should probably take it apart and let it dry when you get in.
What I do like about it is that it has 2 useful white 5 mm LEDs, with a slightly dimmer "low" setting for the halogen, and solid and blinkie settings for the LEDs. (Unfortunately, you can't use the blinkie LED setting in conjunction with the halogen for maximum "be seen" ability.) It also includes 4 easily replaceable AA Ni-MH and a mid-rate (6-8 hour) charger that plugs into the light. I like that the batteries are standard and so easy to change, because you can carry spares with you to extend the run time. I tested about 2 hours and 15 minutes on two different sets of batteries before the output drops and the low battery indicator lights the translucent power/mode button up in red. Once that happens, several more hours of useful light are available from the LEDs. I haven't done a run down test on the LEDs alone yet, but Nashbar claims 20 hours steady, 40 hours blinking for the LED modes.
This would be an OK light for non-bike use if the beam wasn't so tight.
Question: What's the brightest PR2 halogen bulb I can get for this thing? Once again, it runs on 4 AA Ni-MH cells.
