I've lurked here for a bit, and resisted the urge to post because the last thing I need is another hobby ( :shrug: ), but I wound up with a question that I need to have answered. Yes, I tried a search, but I wound up with a lot of info and some of it is older, and I know that the tech has changed a lot in the past year or so.
So, the question:
Please recommend a weapon light for an M16 for police patrol use, given the following information/requirements:
- Durability. This will be a serious use light. It has to stand up to being knocked around a little.
- Reliability. Pushing the switch and getting no light can be fatal.
- Lightweight. My department requires that we use bayonet mounts (picatinny/weaver rail mounted on the bayo lug), putting all of the light's weight waaaaaaaay out away from the fulcrum, so each oz counts. No, I can't move it elsewhere. I'm thinking 2 CR123A batteries is a max. Also, reflector size should be kept small, since the mount is close to the barrel.
- Brightness. We're an urban department, so most of our use is pretty close in. We zero our weapons at 50yds, and we train out to 100yds. The ability to illuminate a threat out to 100yds is important, but I don't want to get too crazy about flooding the target with light at that range, for two reasons: 1. the chance of having to shoot at 100yds is reasonably small, and 2. if we do have to take the shot, we'll probably know he's a threat at that point (we did threat ID drills at that range in daylight, and you can't see a handgun reliably at high noon, so the only way we'd be shooting is if we knew he was shootable ahead of time). Also, we will have to use this light inside buildings, so I don't want to be blinded/dazzled by my own torch.
Right now I'm running a Surefire Nitrolon G2 with a Malkoff Devices LED lamp and a tapeswitch. It seems adequate, but I'm wondering if there is something better? Also, what is the current (11/08) argument re: incandescent vs LED for weaponlights? I "know" (think?) the CW is that LEDs are fine for close up use but you want Incans when you reach out...is that still the case?
Thanks,
Mike
So, the question:
Thanks,
Mike
