Mjolnir
- Joined
- Dec 19, 2008
- Messages
- 1,711
I just received a malkoff 3D maglite mod, and I am trying to find a decent aluminum reflector to replace the stock reflector (which I have modified according to the directions on the malkoff site). However, this is an old maglite, so the reflector and lens both have scratches on them that interfere with the beam.
It seems kaidomain has both OP and smooth cammed/camless aluminum mag reflectors:
Smooth
Textured
These ones have 15mm openings. KD also has similar reflectors with 8.3mm openings, but I am pretty sure this is not wide enough to let the LED pass through.
I am not sure if I want the OP or the smooth. The malkoff dropin makes the mag a good thrower, but the beam hsa a warmer tint than I expected (so it doesn't seem as bright). This made me think of getting a textured reflector to make it floodier. How much does an OP reflector help smooth out a maglite beam (with a malkoff dropin)? Does it get rid of the infamous rings that maglites have when not focused all the way? I suppose I could buy both...
Does anyone have any experience with either of these reflectors with a malkoff dropin? I noticed that they have no tube at all with the cam removed, while the malkoff site says to leave about 1/8 of an inch of the tube while cutting the cam off. Would this negatively effect the light/dropin/reflector/beam quality in any way?
Can anyone vouch for the quality of the KD aluminum reflectors? I know that these chinese sites sometimes don't have the best quality products.
Sorry for the question barrage...
Smooth
Textured
