Re: What nylon pouches/holsters will accomidate SF
The Spec-Ops Brand Multi-light holster will fit the M2 and offers multiple attachment options (vertical, horizontal, Molle compatible) and also has a blue lens "shine-thru" feature that lets you shine the light thru a small blue filter in a grommet at the bottom for a low light illumination situation (reading a map etc..).
Click on sheaths then the Multi-light sheaths on main page
Multi-light sheath
I'm also willing to bet that the Blackhawk modular 37mm Pouch which fits a single 37-40mm projectile would easily fit an M2 which is 1.47" at the bezel end. The pouch has an adjustable lid to accomodate different length projectiles. You could probably contact Blackhawk to verify as I'm sure one of those guys could check it out with an M2. I bet it would work great though.
37mm pouch
If you check the catalog alot of their pouches are double duty for instance the Surfire 3P Pouch has the same catalog number as the Duty Mace Canister Pouch.
Hope this helps you out! /ubbthreads/images/graemlins/smile.gif
Later,
TSG /ubbthreads/images/graemlins/grin.gif
