Hello everyone.I am a novice.Best regards
This is my collection of two HID a flashlight.
Fire-foxes 35W&40W HID The 35W HID.Measurements: L 186mm.diameter 44mm.diameter 70mm,5500k tube.Use three 18650 batteries ,Supply 3,000 lumens light output .Can continuous output 45 minutes.186mm Really very small.
Flux: the 3,500 lumen
Startup time: acuities 15s (cold) more than 3 seconds (hot)
Colour temperature: 5500K
Bulb life: 3000 hours
Volume: 186mm*44mm. lamp holder diameter 70mm
Weight: 420 g. (excluding battery)
Material: 6061 aviation aluminum
Surface treatment: hardened oxidation
Lens material: ultraviolet type high temperature sclerosis optical glass
Stability 35W intelligent digital communication for stability and implement
Battery protection: 10% soc flashing suggest (still don't appear support lithium iron phosphate battery)
Waterproof: waterproof splash
The 40W HID.Measurements: L 210mm diameter 49mm. lamp holder 80mm,Weight: some 900 grams (excluding battery).Use philips 4300K 40W tube.Provide light output 3700 lumens.Use four 18650 batteries,Can use continuously 45 minutes.
Flux: the 4,000 lumen
Colour temperature: 4300K
Lens material: coating type filter ultraviolet broadband increase through strengthening lens (K9 optical substrate)
Optical glass coating: medium membrane protection silver
Startup time: more than 15 seconds (cold); More than 3 seconds (hot)
Volume: 210mm*49mm. lamp holder diameter 80mm
Weight: some 900 g (excluding battery)
Surface treatment: low temperature hard anode oxidation
Ballast: 40 w intelligent digital communication stability device
Output power: 38 1/2 + 0.5 W
Waterproof: IPX7, IP67 soaking, short-term
Supply mode: user replaceable battery frame, battery
The 35W very small and contrast Thrunite
Volume contrast
The left was 35W HID
From left:XML-T6 Olight SR50 Fire-foxes35W 40W
Volume contrast
