Hello,
two days ago i modded my LX2 and L1 with neutral white XM-L led (T5, 3C tint). Everything worked out great: both light now have better tints (especially L1 which had greenish tint before), more output, but they lost a bit of throw.
But the "problem" is, that now i can't see any difference in brightness, beam quality or throw between L1 and LX2, when i use RCR123 in L1. It is a bit dimmer on primary CR123 cell, but not that much. Before the upgrade, L1 was greenier, dimmer and less focused - LX2 had quite better throw. LX2 stays regulated on all cells, driver only adjust the battery current, so brightness doesn't change when using rechargeable batteries. Tailcap current also dropped a bit on LX2, probably because of the lower Vf of the XM-L. Now the runtime on high should be around 2,5 hours.
But here's the trick: while both lights now have more EDC-able beams and higher output, i think i lost the feature on LX2 which defined it as a great duty light - throw. I use my L1 as my EDC (+ quark mini as a backup), and for that application, wider beam is a real blessing - now i don't have to think where have i put that F04 all the time. But LX2 was always a light i put in my backpack or pocket, when i knew i'll need a bit more throwier and serious light, for walking or hiking in a rural area, where i live. I really miss that throwy beam, shaped with that awesome TIR lens - I find it really nice for spotting object up to 100 meters. Way better than reflectored lights! The only drwabacks are, it uses somewhat obsolete LED (XR-E) and beam tint (which is still nice, but neutral is of course better)
So, i need some advice what would you guys do: Should i buy a stock head for my LX2 and sell the modded one, sell the whole light and replace it with something newer? I really want to stay in the "made in the EU/USA department", but there isn't much choice. Maybe Hound Dog but it is really hard to find, or some custom made P60 style lights, but newer dropins seem to be even floodier than M60 Malkoff modules. M3LT is also a secret desire, but it is a bit large, especially since i already have Varapower 1000 as a high output super thrower (de-domed LED = more than 70k lux). What would be my options?
Don't get me wrong: LX2 with XM-L is a great light with high output, long runtimes and great UI, but lacks a bit of a throw for my needs 80-100m), and most importantly, it is just too similar to my (also XM-L modded) L1. I just don't want have two lights that fill the same niche...
I apologize for language and grammar mistakes.
