I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
Less than $300.
I'm flexible, tell me what you got.
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
30-50 yards/meters (I have a big backyard)
10) Run-time: Not over-inflated manufacturer run-time claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
30-60 minutes (I have plenty of batteries just ready to be changed)
90-120 minutes (Run-time is moderately important, but still not critical)
Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
I want a tail mounted switch (found on the majority of today's high end lights).
I want 2 light levels. (Brighter/short run-time and Dimmer/long run-time.)
I want multiple light levels. (Some lights have 5-16 light levels.)
I want a strobe mode. (Blinks to show location.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
I wouldn't mind the possibility of being able to attach different color filters. (Not sure if that's a possibility)
I would prefer a holster able to put onto a duty belt but I could make a clip work also. The ability to attach a lanyard to it would be great.
A Crenulated Bezel would also be great but not a requirement.
I'm very new to the world of flashlights. I have and use a bunch of standard types for every day use and training. It's time to make an investment on a good flashlight that will serve me well.
I appreciate any help and advice that I receive. I've looked over these forums every now and then and since I wasn't able to make a decision on my own.. I now look to the knowledgeable and experienced flashed light users to help me with my decision. Thank you all for your time.
Less than $300.
3) Format:
6) Manufacturer:
