Nice pretty, shiny, anodised aluminium, only 27g. 45 mm long x 24 mm diameter. Can screw onto a mounting lug as shown in the paulcomp.com pic above, but can also screw directly onto your quick release.
Is there a downside? For me, I really don't like the beam pattern it produces at that angle. Oh well, looks like I will have to consider pushy's set up instead.
.... im not sure how it would be for offroad but for the road it might be a good idea so you wouldnt be blinding car drivers. post thooughts comments and ideas here!
The lower a light is mounted, the more likely it gets to blind oncoming traffic. But it's also much better to judge road/trail conditions because of the longer shadows casted.
The higher a light is mounted the less likely it's to blind, but it also gets harder to judge road/trail conditions because of shorter shadows casted.
The XC-997A from DX is 1W at full power, and ½W at low power.
Current consumption is steady for battery voltages between 4.8V and 3.6V due to linear driver circuit.
Beam is shaped like a low trapezoid with wide bottom.
