lumenman1776
- Joined
- Dec 21, 2008
- Messages
- 8
Hey everybody,
I just received my JetBeam BA10 today that I ordered from battery junction and thought I would give some first impressions.
Fit and finish- Seems very well put together on par with my Eagletac P20A2. Threads came pre lubed which is good.
Brightness and beam profile- Using 2450mah nimh rechargeables it is very bright for its size however I do not believe it is 160 lumens. Comparing it to my Maglight xl50 it appears to only be slightly brighter. otf output is probably some ware around 120 lumens. The beam is more floody as one would expect from such a small reflector but it has no problem illuminating objects at 50 yards or so.
Modes and operation- The BA10 only has two modes which is fine but I wish it either had a brighter low mode than 12 lumens or a middle mode of 45 lumens or so. It has a momentary on feature which is also good.
I have not had a chance to check the runtimes but because its going to be an occasional use edc I don't think the short high runtime will be an issue. Also the pocket clip is not reversible which kind of stinks but it's not really a big deal.
This was my first order from battery junction and their service is great got my light in three days. I will definitely do business with them in the future
I will keep you posted as far as how long the charge on these batteries last.
