So I'm looking at the surefire fury 500 lumens 12000lux(maybe not sure about lux) and than the eagletac g25c2 mkii 950 lumens 21800 lux. Well I was reading a forum and a couple people said there is nothing brighter in its size than the surefire fury. I'm not trying to bad mouth surefire or talk up eagletac but on paper the eagletac is a good amount brighter due to its lux and plus higher lumen, so my question is am I the ignorant one, or what's going on?
There's plenty brighter than the SF Fury in that size...about every single 18650 or 2x RCR123 light for example is brighter than the Fury.
I like my Fury, but my Klarus XT11 is brighter than it with a single 18650, and a LOT brighter than it with two IMR6340's...and the XT11 uses old creamy white T6 XML's, not even the newer brighter U3 XML2's, etc.
So, instead of the Fury being the brightest for its size, its not even brighter than ANY of the newer U3 ones in that size range, and its even dimmer than some older T6 lights in that size too.
And, those Eagletacs list both the LED/Emitter lumens, and the ANSI lumens...but I see a lot of references in the thread to the LED lumens, but, the new stuff can still kick the Fury's lumen-***.
So, now you also know who at the other forum, who's telling you that the Fury is the brightest, is probably not a reliable source...and to now take everything they say with a grain of salt, etc.
On the flip side, the Fury is very well made, I've never had a hiccup from mine, the beam shape is pretty good even if the lumens are shy of a full load, a decent somewhat floody beam, useful, etc. The tint is not great, as they tend to go to the green end of things to maximize lumen out put, ironically.
Also - By MAKING a light dimmer on purpose, it also allows a longer run time, and can avoid needing a step down...as its essentially ALREADY stepped down, etc.
Lumens are not EVERYTHING...they are part of everything.
