thijsco19
I'm looking for some 26650 batteries to use in my convoy L5 host, here is an other topic from me about this host and what to use: http://www.candlepowerforums.com/vb...-MT-G2-driver-with-2-cell-light-(26650-18650).
This topic is primarily about the batteries.
Some basic info:
2 cell in series.
Not yet sure about what led to use, there are a couple possibilities:
MT-G2, might drive it to 4A, not much higher then that.
XHP50, same as above, maybe 4A, not much higher.
XM-L2, probably also 4A.
There is not much room to fit 2 protected cells, I measured it at 137mm, so 68.5mm for a single battery. I might get rid of the spring on the driver board to increase it with 1mm.
So there isn't room for protected 26650, at least the ones I've found.
That brings me to my first question, how safe is it to use 2 un-protected cells in serie?
And second question, what kind of battery do I need, a high capacity or high discharge current battery?
Personally I want the highest possible run time.
Is this battery a good choice?
http://eu.nkon.nl/rechargeable/26650/keeppower-26650-5200-li-ion-battery-20a.html
Thanks.
Some basic info:
2 cell in series.
Thanks.
