Mr. Nobody
Does anyone currently make a triple mt-g2 light ? That would be a pretty bright light in a relatively small packege.
Depends what you mean by small and bright.Does anyone currently make a triple mt-g2 light ? That would be a pretty bright light in a relatively small packege.
Running 3 x leds at lowish current each should be more efficient than running a single led at highish current. But if you keep to the same physical sized host, you'll get less throw too.
If you want to run 3 leds each at highish current, then you'll get really short runtimes, or you'll need lots of big batteries.
I think you will need some batteries that can handle high amp draw too. Then some nice large heat sinks or forced air induction cooling or perhaps water cooled?? :twothumbs
Why are there no water cooled lights... good point. I know you need to be able to circulate the water, but maybe that could be done by body movement or something when walking with a light. Dunno just a though.
You mean like the Acebeam X60m? http://www.acebeam.com/acebeam-10000-lumen-x60m
I suddenly have a vision of a flashlight built around a water jacket like those old WWI machine guns. When you run your light on high steam would come out. Eventually you'd have to refill your light.... haha!!
Does anyone currently make a triple mt-g2 light ? That would be a pretty bright light in a relatively small package (for $x).
mvyrmnd said:mvyrmnd[/URL]]You mean like the Acebeam X60m? http://www.acebeam.com/acebeam-10000-lumen-x60m
That's a sick light. Looks really really expensive tho.
Thrunite tn36 3xmkr close enough?
TN36MVn - TN36 modded by Vinh with 3x MT-G2. Pretty bright. Small package.
It is and it isn't.It's kind of nuts that lights like that x60m are starting to get close already to what that xm18 can do with literally 18 xm-l emitters.
It is and it isn't.
Sure emitter technology is progressing, just think back 10 years ago what LED lights were like then vs now.
But it's also about how you want to wire them together.
There are plenty of car based led light bars you could adapt and run off of Li-ion batteries.
1 x li-ion will direct drive 3 XM-L2 leds for a short while. And get maybe 3000 lumens+
Something with 8 x 18650's isn't out of the question. Runtimes on max would be low, but better on lower settings and still loads of lumens.
That would be 24 LEDs in total and up to 24,000 lumens+
Heat would be your major issue, but just for fun you could build it without the need for any drivers at all.
