Prepped
- Joined
- Aug 16, 2015
- Messages
- 325
So I just did a little snooping on Thrunite's website and came across this...
Specs on the Thrunite website
The Ti5 is a very compact and lightweight "penlight" style LED flashlight, which is small but bright (give output up to 120 lumens just using a single AAA battery), simple but functional (fouroutput modes for choice: Firefly, Low, High and Strobe). The perfect combination design of tail switch and twist switch gives the Ti5 three operation methods for easy and quick to access your desired output.
Features
- Always have the light you need when you need it, with this "penlight" style Ti5 LED flashlight—great for a variety of applications from daily life, specific work fields, outdoor activities to emergency use.
- The hard anodized aircraft-grade aluminum body is easy on the skin, feels good in the hand, and looks fashionable to carry.
- Adopts an advanced CREE XP-G2 R5 LED to give max output up to 120 lumens with a max regulated runtime for 120 hours.
- Silent Momentary-on "forward clicky" tactical tail switch for signaling or brief lighting.
- Due to thoughtful design, the Ti5 always starts in Firefly mode—ideal for tasks like dentists, using it as an endoscope.
- Outstanding construction gives the Ti5 the durability to meet the IPX-8 waterproof standard.
- With a non-detachable stainless steel pocket clip, you can securely attach the Ti5 to the belt, pocket or anywhere you want for easy access and carry.
Specifications
- LED: CREE XP-G2 R5 LED with a lifespan of 20+ years of run time.
- Output & Runtime (Tested with 1*Ni-MH/900mAh): Firefly (0.2 lumens /120 hours), Low (11 lumens /6.5 hours), High (120 lumens /30 minutes), Strobe (120 lumens /1 hour).
- Neutral White output will be 15% less than Cool White.
- Working voltage: DC 0.9V-3 V.
- Battery: 1 x AAA battery (not included).
- Peak Beam Intensity: 660 cd.
- Beam Distance: 51 meters.
- Waterproof: IPX-8 (2M).
- Impact Resistance: 1.5M.
- Material: Aircraft grade aluminum alloy body structure with premium type III hard anodized anti-abrasive finish.
- Reflector: Orange peel reflector gives perfect flood.
- Weight: 20g (without battery).
- Dimension: 90mm(length)*14mm(head diameter).
- Working temperature: -40℃ to 40℃.
- Accessories: 2 x Spare O-ring.
Looks interesting!
Although, I am a little confused as to why the Max Lumens are listed as both 120, and then 300 further down the page.
Probably one of Thrunite's common typos.
Features
Specifications
Beam Distance | 54 meters |
Max Lumens | 300 lumens |
Waterproof | IPX-8 |
Runtime | 137 hours |
Impact Resistance | 1.5 m |
Looks interesting!
