Apologies if this is in the wrong forum
Very long time reader, very intermittent poster!
Bought a Maglite 6D as it was very cheap indeed.
I'm looking at putting in one of the DX 5x Cree bulbs in and have searched the forum extensively on how to do it.
im going to get hold of a file set and some bits for my Dremel to take a few MM off the head so that the bezel and lens fit better.
However - it looks like there are two options.
1) insulate the positive centre spring using heat shrink or similar and manipulating the outer spring to make contact with the outer portion of the bulb housing.
2) hard wire it in
ill try the first option however I'm prepared to go for the second but I just took apart the switch completely and can't see how people have attached/soldered wiring onto it.
If someone can demo where I need to solder on the pos/neg wires then I could just wire it in!
Any ideas?
thanks!
2) hard wire it in
Any ideas?
thanks!
