Calvin0807
Introduction:
The VOLLSION SP11-S EDC flashlight Utilizes Cree XP-G2 LED with a lifespan of 50000 hours,it turns AAA-tiny battery into useful personal lighting with 110 lumens max output. Simple twist switch operation manages two brightness levels in this 63.8mm flashlight. Stylish stainless steel construction 、excellent Optical system、IPX-8 waterproof and drop resistance make SP11-S to be a great exquisite EDC assitstance with the great anti-corrosion.And the special design on the tail with the lifespan up to 25 years Tritium tube make it more glowing in the dark
Manufacturer specifications:
CREE XP-G2 LED
Micro orange efficient metal reflective cup +optical double coated lenses
High quality304 stainless steel shell design
High efficiency constant current constant light circuit 2 gears
110 lumins for 1.5 hours
5 Lumins for 60 hours
Maximum intensity:450 candela
Maximum range:45meters
Head rotary phase(tighten to close ans loosen to turn on)
Weight:22G(not included battery)
1piece AAA battery(compatible 10440 rechargeable lithium-ion battery)
No obstruction hole,perfect inverted,used like a candle
Filled 25 years life tritium tube on the bottom
IPX-8 grade waterproof(submersible to 2 meters)2 meters drop resistance
Standard configuration:waterproof O ring*2,key ring*2
Packaging:
Simple packing by kraft paper box,both front and sides have brand logo,the front is product information,and the side is parameters.
Accessories:
There are sponge protection to flashlight,manual,accessories,etc.Just lack of lanyard.But it is dispensable
LED:
The XP-G2 LED ,right in the center ,better than FENIX E05SS
Build quality:
Exquisite knurled,it is stainless steel material,slippery resistance effect is much better than aluminum alloy,smooth rotate the head to adjust the open or close and the light intensity,very simple but elegant lovely knurl,texture and handiwork is top-notch
The tail of the flashlight is T shape design,half is key ring hole,and the other is tritium trachea slot
The feature of the tritium trachea,it is in the middle,plenty of light,the tritium trachea is just 1 color,only in the dark can appear different colors
Square thread
Gold plated spring head,conducting more efficient and not easy to oxidation
Blue coating lens,can be seen from the both sides of the blue light
20cm beamshot,perfect!
1 meter beamshot ,And you can see,this flashlight's tritium is green, i can quickly find the light source and use it in a dark environment!
Compared with Iphone6s!
Compared with SwissGear!
2 pictures about the tritium !
Light up in the bucket for 30 minutes,the waterproof ability is OK!
My thoughts:
Compact size. Excellent quality , all the details are well done !
The dimming method is very very good,it can avoid losing its head (if it is losen to turn off , the head will eally be lost when we carry it everyday)
the tritium tube,is very beautiful,though it is not too big, it can help me to find my keys and flashlight in the dark,and five colors for choosing !
but the appearance design is too ordinary!
Thanks for reading my first review ! !:laughing:
CREE XP-G2 LED
Packaging:
Accessories:
LED:
Build quality:
Square thread
My thoughts:
